Spare wheel cover key
    I've also just purchased a 120 prado and the seller didn't supply the key for the wheel cover. I found that with some pressure on both sides of the cover down low it would come loose enough to slide off the bottom and then I can still lift it off then. I was also lucky the the lock is also missing for the nut on the spare wheel holder.
    I found on eBay a replacement lock for the cover if I can figure out how to get the old one out and a lock for the nut.
    http://m.ebay.com.au/itm/281480224834?nav=SEARCH
    http://m.ebay.com.au/itm/271554438084?nav=SEARCH
      The actual nut/lock on the spare wheel itself is unlocked using the ignition key....Cheers Steve
        http://ebay.com.au/itm/281480224834?nav=SEARCH
        http://ebay.com.au/itm/271554438084?nav=SEARCH
        Hey mate, this link didn't work. I will try and get this sorted over the weekend too IF i have time. Otherwise the weekend after.
        Thanks!
          Hey turbo I'll be down seven hills way on Saturday, your welcome to try my key on the off chance it may work,.... Cheers Steve
            No way, that's where I hang out!Saturday I will be fishing though
            Been waiting for this day, first time towing with the new car!
              Thanks!
              Think I fixed the link. Cheers
                I'm always down there that's where the in laws live just off Monaro st..... Cheers Steve
                  Yes this seems to work! Good find!
                  What is involved in removing the old lock? Is it just pop rivots?
                    sorry it was correct myebay took me to a picture of another locking nut..... Cheers Steve
                      I haven't'the figured that bit out yet but that could be all there is to it. We need someone to show a picture of what it looks like unlocked.
                        If I remember tomorrow I will take a pic for you and post up.... Cheers Steve
                          It looks like you can remove the tab from the barrel via a screw, or the nut can slip over the tab. Don't think there are any pop rivets involved from the ebay picture.
                          • #28
                            All sorted. Went to a locksmith. Did the whole job for $55. Didnt have to order new locks.
