They don't quote any relevant testing standards. That worries me as much as pulling something from the nudge bar on the John Deere. Certified to something then maybe ok.
I can see someone forgetting to slide the loop up correctly and the whole thing coming undone mid recovery...
And aren't standard bow shackles significantly cheaper anyway??
Spilsy
The only real benefit I can see from these would be they wouldn't be a flying missile if some how something became detached.
Dan
22'' Lightbar......
I reckon this looks great - as said, easy to stow and unlikely to be deadly should it become a missile!
Prado 150 D4D AUTO GXL with ARB Deluxe Winchbar, Brains' TG150 Transfer Case Actuator Guard, Bilstein/Ridepro 50mm Lift, Safari Snorkel, D697 265/65/17 LTs, Dual Battery Setup with REDARC Controller, REDARC Tow Pro, Toyota Tow Bar, Maxtrax - towing a Camprite TL8s fitted with GXL wheels and D697s.
Don't underestimate the strength of rope. Been used for lashing and lifting loads for thousands of years. Simple, strong, effective. Just shows that what is old is new again, albeit in plasma form.
Have made quite a few of these from 10mm and 12mm Dyneema/Spectra for both sailing and 4wd purposes. Easy to do. Lots of Youtube videos show you how. They are very strong, light and easy to stow. Haven't broken one yet but you do need to be careful of cuts/abrasion. You might get some shorter lengths of rope from a sail riggers to try out.
