Building a workbench for the garage, I have got the basic design in my head, however is there a reccommended height for the bench? or is it whatever you want?
All feedback appreciated
It depends on what you see yourself working on, but generally between hip and elbow height is a good benchmark (~800-900mm). When I was working on PC's, I found that 700mm was perfect for me because the PC cases were around 150-200mm wide, so I could still lean right over the top of them comfortably. That bench had a fluoro light mounted at 2100mm to give lots of overhead clearance, but it's too low to be practical as a proper workshop bench. I knocked up a heavy duty workbench for general tasks but built that at 900mm. A good height but I can't lean over that one if I need to. If I need to do that, I can stand on something for a bit of extra height.
Googling "Workbench height" turns up a stack of useful info
It depends how tall you are and your health. I.e. I'm 6'3" and a dodgy back so I prefer a high bench so I'm not bending over as much.
Mines 900mm with a shelf mid way up, works for me. I would suggest putting a small lip maybe 20mm high along the back. Nothing worse than a small nut/bolt etc rolling off and going behind/under the bench.
I have two in my shed.
The old original one is at 900mm
The new one that I built is at 860mm.
They both are fine for me, just depends on what you are working on. I do prefer the 860 one. Will take a photo if you like.
Mine is a real old home built one dad threw together 30 odd years ago and it stands at 939mm's and one I purchased from the local hardware that stands at 840mm's,depending on what I'm doing I use which ever one fulfills my requirements and find both are comfortable to use.
Cheers.
I can feel this morphing into a 'show me your bench' thread
Your on report D4D! That bench and workshop area is way to tidy, and a flat screen mounted over head as well. tutt tutt tutt.
Good pic V. envious!
Troy
Nothing wrong with tidy. A tidy work place shows an organised mind.
Yes, I'm an OCD neat freak too. That looks great to me. #mancave
Guys
thanks for the feedback, it looks like around 900mm is the go for me any way.
D4Ds workbench has inspired a case of bench envy.
My old one (dating back to 1920s) was wonderful but did not fit in the new garage so went to my brother.
