Hi,Im doing a new setup in the car and am after an outside point of view.
I sold my thumper due to size of it (height) and was going to buy a 200ah deep cycle agm. This would be permanently mounted in boot, to run fridge. Car is usually driven daily so at most if it sits 2 days the fridge might drain 40-50ah (75%). so the agm will be close to full charge all the time (well its off isolator in 120 grande, so probably 13.5-13.8V?), hopefully getting long life. it might from time to time (like once a year) get LEDs attached for camping, but will probably never discharge more than 50%. This battery is a f@#king tank. 600mm long (not too much issue) but 65kg!!!!!
other option is to pay nearly double for a 50-60ah lifepo4 which weighs less than a quarter (im not too fussed on size, just weight, as my draws alone are 60-70kg, plus fridge). so the lifepo4 battery would quite regularly be discharged over 50%, sometimes closer to 80%. plus im not sure my projecta electronic isolator will charge it (so more money).
The way im planning to use the batteries, which battery would be better off?
Any other things im missing?
im thinking even if i get half the life out of the agm, in 3-4 yrs the lifepo4 might be heaps cheaper so not much point getting it now.
