Prado 150 Rocker Cover cracked 100,000 kms
  • Prado 150 Rocker Cover cracked 100,000 kms
    Hi All,
    Just completed my 100k service on my 2013 150 Diesel . Advised i have a cracked rocker cover. Car has been serviced every 10K at Toyota . Of course it is out of warranty. I am a little concerned and disappointed that A- this has happened at 100K on a completely stock std vehicle and B- Toyota's response... Tough luck mate - That's $ 450 BUCKS.
    I assume at the 80K service as per book service, valve clearances are checked. Would this not mean they remove the rocker cover. Amazing, 20000km later its cracked.???????? Oh what a feeling I don't have.....
    Could you post a picture of where it cracked or has the job been done already?
    If it's cracked at a bolt position I think it's worth taking further since you're correct in that only Toyota personnel have been in there.
    Cover is designed to be removed and re-fitted numerous times without failing.
      Originally posted by Jagman View Post
      Hi All,
      Exactly.
      Don't worry it will be minor.
      2 options.
      Clean & a Little black silicone. Or
      Wait till 120 & replace it then. Can get them for under 300. Closer to 250 I think. Seen it a bit.
        Got my 2013 model back last week from the very expensive 120,000 klm service and was told the rocker cover was cracked and needed replacing at a cost of $540. The service man said that they see that quite often, two or three a month. Just had it done today and kept the old cover and the crack is at a bolt hole. How many more have had the problem and did the company come to the party in any way. I feel like taking it further.
        Jeff. 2013 GXL Diesel. ARB Bar, Safari snorkel, Tigerz 12000lb winch, OME 2" lift, Aux battery with CTEC 12v -12v and solar charger, 100w solar panel, Rhino bars, shovel holder, Oztrail canopy, Maxtrax, GME 3220, Toyota tow bar, Tekonsha Prodigy, Hema navigator, Tyredogs, Waeco 50l fridge, ARB compressor, Rear door table, Fire extinguishers front and rear, cig plug and 2 Anderson plugs in rear.
          250,000 k and no cracks for mine. I do my own servicing after warranty was out though. I would say it has been over tightened and that has made it crack. Doesn't need much only 9nm so easily over-tightened.
            Unless it is a design/manufacturing fault, which it doesn't sound like, then it is due to over tensioning.
            [B]Steve[/B]
