HI all i was just want to know if there is any difference between a 2001 1kz te prado and the hilux tappet covers as i am trying to put a prado intercool on the hilux. The hilux one seems a bit high can anyone help thanks.
difference between prado / hilux tappet cover
Looked into this tonight (I have a mate with a non intercooled 1kz-te)
The rocker covers are different, the Prado cover has the bulge/port for the crank case breather right at the back (non intercooled one is in the middle)
The intercooler mounts over this at a slight downward angle towards the front (to follow the slope of the bonnet).
I also noted the Prado engine sits much lower in the engine bay so you may have some clearence issues with the bonnet to work around.
