Hi Lift jack bracket - 150 GXL
  • Hi Lift jack bracket - 150 GXL
    Hi all,
    This is my first post so I hope this is the right forum to ask this question.
    I'm trying to find a Hi Lift jack bracket that can be used or modified in some way to fit onto the factory spare wheel holder on a 150 GXL. The 'through the centre of the hub' type are no good because of the camera mounting bracket on the 150 but I'm happy to relocate (or remove) the camera if necessary even if it meant putting on a completely different door mounted wheel carrier.
    I have a flat roof rack carrying a roof top tent, 2 jerry cans and 4 max trax so there is no room (or weight capacity) to mount it up there. I've seen brackets to mount it to the bull bar but I don't think it will fit (I have an ARB bar and it may hit the UHF aerial) and would protrude past the front of the bar so I don't think it would be legal anyway (in WA).
    Anyone have any ideas?
    Thanks.
    leave the high lift off, it will save you 12kg of weight and a lot of heart ache when you damage panels
    get your tyre pressures right and stop before you bog yourself right down and just back out
    just my thought's !
      Thanks, I've done many trips without it and always done as you suggest with tyre pressures etc (down to 8psi if required) and did consider not taking it on this trip (Ruddall River NP and Canning Stock Route) until the trip organiser asked if I was taking it. I understand re panel damage but it would be good to have as a last resort. Cheers.
        Originally posted by Freaks View Post
        Hi all,
        Thanks.
        Try the ones that Kaymar make. Different styles to suit a wide range of vehicles.
        http://www.kaymar.com.au/parts_wod.php
        Dennis
        Ag Nomad
          ask him if he is taking 1 , if not you can lend him yours
            Thanks boomer52 I had checked the Kaymar web site and called a local Kaymar distributor but they don't have anything. Cheers.
              Thanks Razorback81 - he doesn't have a hi-lift jack but has a 2nd spare wheel & jerry can steel bar on the back of his LC200 which should accomodate one of the 'through the hub' type of shovel/jack holders. Cheers.
                I have mine on the roof IMO the less weight on the rear door the better
                Prado 2014 Manual GXL, TJM T13 Bull Bar, Recovery Points, TJM Side Steps, TJM 9500 Winch, Airtec Snorkel, Lightforce 180SD LED Lights, TJM XGS Springs & Shocks 2" Lift, Toyo Open Country AT2, Hayman Towbar, Rhino Backbone and Platform, Tanami Drawers, Clearview drop slide, Engel 40L, Redarc Brake Controller, Hema Navigator, Kings Awning
                Off Road Camper Trailer ~ 2014 Toolman Explorer Hard Floor
                  I have seen a setup where two brackets are welded to the end of the towbar which allow the jack to sit horizontly just below the rear door. The jack was wrapped in canvas to protect it from stones and dust.
