Rear battery: AGM or Lead Crystal or Lithium
  • Rear battery: AGM or Lead Crystal or Lithium
    Anyone have a Lead Crystal and have any performance views compared to AGM?
    mjrandom mentioned the lead crystal in the Optima Fail thread:
    I'm giving lead crystal a go as an aux. if it is as good as the specs suggest it will be very good indeed.
    mjrandom. Did you try the lead crystal battery? Our 60A Thumper, it has been good but now looking for better performance. AGM or Lead Crystal 100AH would be better but heavier and dearer...
    Saw a lot of hype about the Lead Crystal on Andrew White's youtube about his troopy build. A bit after 4 minutes in:
    The LC battery @ 120AH 6-CNFJ-120 is around $660. Globalsat has the 110AH @ $529 http://globalsat.com.au/product/lead...ry-6-cnfj-100/
    Lithium is also a possibility, but might be too new for an outback vehicle. Needs more testing probably to prove it is better and safe.
    I did go ahead with the lead crystal (120AH) and it is very good. I put a 160W nuclear power station on the roof at the same time and all is going to plan.
      Hey all,
      Interesting claims by the lead crystal club, 18 year service life, wider operating temperature range etc....but hard data over 18 years, even harder to find!
      I have read reports of failures in 2-3 year period with minimal use. Take from that what you will.
      Interesting electrolyte phase transition from liquid to solid during charging, but like all batteries, they are made from a bunch of different phases which eventually become electrochemically inactive through cycling/oxygen/dendritic growth of undesirable phases. Really just another fancy AGM.
      Couldn't hurt to try one though, my AGM is down to 50% capacity after 7 years with minimal use and not a lot of maintenance!
      Best
      Mark
        You are correct that lead crystal is just a fancy AGM and that the claims of life seem far fetched but my main motivation was the cycle duty. Our previous AGM wasn't that old and hadn't been cycled that hard but it was rapidly declining. It needed replacement and I was able to get the lead crystal battery for around the same as a Fullriver AGM so thought why not? The solar feed makes a huge difference so I probably cannot make a direct comparison. My last AGM was a Ritar brand and I wont go there again!
        provably fair bitcoin casino
