Adding Cruise Control in LC Prado 150 year 2012
  • Adding Cruise Control in LC Prado 150 year 2012
    Dear All. I have LC Prado 150 make 2012 2.7L 4-cyl with 2TRFE engine. I have connected the aftermarket cruise control stalk and its connecting cable inside the steering wheel. The cruise control did not work. Looks like the cruise control was not pre-wired. Please guide me about how to make wiring for this. I will appreciate if exact connection point is shown in the form of picture or diagram. Thanks.
    May need a different clock spring with more cables/ connections in the Squib ribbon.
      I came to know from one of the posts here that one wire needs to connect from control stalk to ground and one to the ECM. But I can cannot figure out the exact pin in the connector of ECM.
        Anyone having information on the above...please share
          Did you read the replies?
            Yes I read the reply. The clock spring already contains the port to connect the CC stalk and the spare pins behind the steering to connect the wiring (one ground and other to ECM).
              But does it have the right amount of cables in it., Ive seen clock springs with the connectors, but not connected thru the squib cable... Get techstream plugged in and you can test the buttons to see if they are working.
