Slight vibration
  • Slight vibration
    Have a vibration that goes through Prado. Can be sitting at lights in neutral and feel vibration through gear stick as well as steering wheel. It’s not an excessive vibration but can also see it through rear vision mirror now and then as well. Driving me insane as to what it could be but also did just have to rear engine mount replaced because last one was cracked and worn and that did take away about 50% of the vibration, but there is still vibration there.
    Any suggestions would be great as also though it was driveshaft until I’m not moving and in neutral and it’s still there. It’s a 2012 150 as well
    I can't figure out what it is, but I recently had to replace the rear engine mount since the old one was fractured and worn, and it helped a lot (it eliminated about half the vibration), but it's still there.
    Until I tried not moving and going into neutral and it was still there, I assumed it was the driveshaft, so any advice would be much appreciated. It's also a 2012 model year 150.
    drift hunters
      Should you take it for a full checkup to see if any equipment needs to be replaced or maintained? and find the cause of the vibration. vampire survivors
