Well as you know, I'm pretty new to the Prado. I've just fitted Ozi4x4 Projector headlights and notice something odd. When switching to high beam, only one projector per headlight is working (the high beam, not the low beam). The low beam switches off. This results in a pretty poor high beam. The headlights are LED and use the OEM wiring. I wonder if there is an issue with the relay or if this is the expected behavior.
If this is the expected behavior, 'I wonder if the wiring loom and Circuit completer from Piranah is the solution, A post on this forum speaks about making your own but the diagram is no longer available.
