Prado 150 or Landcruiser 200 which is the better
    Re: Prado 150 or Landcruiser 200 which is the better
    Originally posted by carrington
    Do you have pricing for the anniversary model on the road ?
    All I know is it will be more than GLX and less than VX.
    Im hopeing its low $90000.00 drive away
    150 Prado D4D GXL Blue Storm, T13 TJM Bar, 265/70/17 Goodyear MTR Kevlar, Tigers11 1200 pound 2 speed Winch, Fox Shocks remote resevor, Air tec Snorkel, ARB Air Lockers Front and Back, Off Road Systems Draws with Drop Down Fridge Slide, Wetsuit seatcovers.
      If you are towing something substantial the 200 TTD is the way to go, 650Nm nothing will go close.
      If your only towing a camper trailer or so, the Prado D4D would be a good choice.
      I had a 2008 Prado Grande D4D, it was an excellent vehicle, but when I hooked up a 2.1 Tonne van behind it, its ass was hanging out.
      Now I have a 2010 200 TTD, and it flys, it is like nothing is on the back.
      Thats 127Kw 410Nm V 195Kw 650Nm No competition !
      Re : The Injectors, ALL D4D common rails Need Clean Fuel, if you dont get it they will all be in trouble !
        Originally posted by Davros
        easy.
        4.5L twin turbo v8.
        I would disagree with that. It is becoming more evident that the 1VD-FTV is prone to complete failure around the 80-90,000km mark.
        Some are using a hell of a lot of oil, the jury is still out as to where the oil is going.
        Have a little read below............
        http://www.lcool.org/forum/viewtopic.php?t=11882
        http://www.lcool.org/forum/viewtopic.php?t=9212
        http://www.lcool.org/forum/viewtopic.php?t=11613
        http://www.lcool.org/forum/viewtopic.php?t=5618
        http://www.lcool.org/forum/viewtopic.php?t=10836
        The 1VD-FTV is a lovely motor to drive and make no mistake, it's a real towing powerhouse. I've driven one with a couple of hundred kilos onboard as well as a heavy trailer and the V8 just won't surrender - even on hills. You are quite right to have reservations, because as you say, there is a significant engineering condition which is causing them to use a large amount of oil. The V8 I drove used around 5L of oil over a hard trip and it had about 45,000 km on the clock. I was somewhat shocked to check the dipstick to find it was at the bottom level before its next service was due. If you plan even a moderate trip it would be mandatory to carry spare oil and to check the dipstick every time you fill-up. This is an expensive, inconvenient and potentially damaging drawback to this otherwise impressive motor.
        2004 GXL V6, 5 Sp Auto
