battery charging
  • battery charging
    hi guys
    just wondering - when charging the main battery of your prads - do you bother disconnecting all the clamps, or is it ok to leave them connected and just clip on the aligator clips on to the charger???
    probably a silly question, but just not soemthing I am sure of.
    cheers.
    scott
    Re: battery charging
    just leave them on with the ignition off, thats what i do, but i also have to disconnect my 2nd battery as the charger tries to charge both of them and really struggles. cheers samo
      i just clip on the charger to either battery, and it charges both at the same time.
      i have a bigger charger than Samo
        thanks guys.
        I will charge it with the second battery still connected just to see how it goes - otherwise I will just charge them seperately.
        Do you guys bother disconnecting the second battery if you arent using it?? (not when charging I mean) or do you just charge it and let it run low over time without the draw of any appliances??
        cheers
