Re: Dig_Options TP09X1 GPS, Reviews & Information
  • Re: Dig_Options TP09X1 GPS, Reviews & Information
    Originally posted by bdaearth
    Just one other thing, can you see the tow ball from the position??
    I've got mine adjusted so that I can 'just' see the tow ball/trailer hitch when its in. I didn't want to have it pointing too low and miss out on the advantage of reasonable good rear view distance.
    While the camera bracket can be bent and twisted a bit to help get it adjusted as required, I'd recommend doing a bit of a test fit using double sided tape or just one bolt first to ensure you can get it the way you want it. Note that depending on the tyre size/type of your spare, you may not be able see the actual bumper.
      Cheers rossd now were is my drill :shock: :? 8)
      [color=#FF0000]ECB ally bar, IPF HID upgraded, dual battery with CTEK dc to dc inverter, 32lt Engel, Safari snorkel, GME UHF, Maxtrax, bridgstone duelers, Offroad camper Trailer [/color]
      [color=#0040FF]WISH LIST: lift kit, Onboard compressor,recovery points [/color]
        Originally posted by Willo77
        I have had the Premium unit installed since around the end of October and have experienced a number of glitches. Has anyone else experienced a problem where the unit somehow deletes all the GPS data off the SD card. I have now had this happen twice and it is quite anoying when you are away and relying on the GPS function.
        I also thought I backed up the SD card when Matt sent a replacement but when I copied my "back up" onto the SD card there are no iGO8 files.
        Hi Willo, have you updated the firmware? If not, please email me at [email protected]. Regards, Matt
          Has any one come across a blank screen , as mine wont show anything. I purchased it in april 2010 high def model. i can hear radio at times so power to the unit is ok i have sent a email to matt , and hope to fix soon as possible , it has been a great unit until now. Randy
          05 charcaol tint, alloy bar hella lights scangauge11 uhf remote head, polaris with rear cam,bonnet ,side windows,and rear window plastics TPO9X1 replacement
            Originally posted by lionel
            Chippy,
            Given only one image is displayed at once, could you use a 3 position switch (stone) to kill both birds above? I'm thinking out loud here, but bear with me:
            1. Front camera on
            0. Rear camera auto
            2. Rear camera on
            Wiring as follows:
            Use a two into one RCA joiner (eg stereo audio -> mono) on the camera connection to combine the video feeds
            +12v source to a 2 position switch (e.g. http://www.jaycar.com.au/productView...T&SUBCATID=401)
            wire from position 1 to the 12v input on the front camera (e.g the piggyback wire - potentially need thicker gauge) and through a diode to the brown wire
            wire from position 2 to the 12v input on the rear camera (e.g. the piggyback wire - ...) and through a diode to the brown wire
            wire from reversing lights (or the kick panel) through a diode connecting to the wire from position 2 before the diode
            The logic is, with the switch in position 1 the current flows from the 12v source through the front cam and to the brown wire. In position 2 it does the same but with the rear cam. The third diode stops the rear lights from coming on. With the switch in the centre, if the reverse lights are activated, the rear camera will come on
            Wiring Diagram:
            Apologies for the hand drawn diagram and amateur electronics (read made up symbols), if anyone can improve I'd love to hear your feedback.
            -edit- needs an earth on the rear camera too ops: -Diagram for illustrative purposes only :lol:
            Ed
            Lionel,
            Thanks for the good idea (and wiring diagram), I have run with it and come up with an override so that I can activate the Reverse Camera on demand.
            (To All - yes this is a handy feature but not safe to be travelling fwd and looking at the world wizzing past in reverse...)
            I used the following switch from Jaycar as its very similiar in size to the carlingford rockers but much cheaper:
            At this stage I'm still considering where to mount a front camera before I proceed. Not a huge fan of the front badge location of the 150's Kakadu - thinking about mounting on the underside and perhaps on the crossmemember below the gearbox/transfer case - that way when looking forward I'll see both front wheels for wheel placement and also clearance of the front end over obstacles.
            Anyone got other ideas?
            Micheal
            Micheal.
              Hi Randy, this sounds like a faulty monitor. You have thrown me that you can hear radio at times, or is it all the time? We do offer a 12 month warranty so unfortunately will need it back to look at. Please email or PM me and we'll get it resolved asap.
              Matt
                I'm interested in getting a new GPS/Radio/DVD/Rear camera unit and have just checked the eBay site but there seem to be dozens of different ones that fit the Prado. Which is the one that everyone is talking about; the TP09X1 model and I see that Matt from DigOptions says there is a Premium model. Which is which and which is the Premium model???
                Everyone seems to be satisfied with this model, I don't want to buy the wrong one.
                Also does anyone in North Brisbane install these things as I have no idea what some of you are talking about when you are doing your own installations. That's not within my capabilities.
                [color=#fa0c23][b]
                Brian
                [/b][/color]
                [color=#004080][b]2011 Silver GXL Diesel Auto with dual batteries & pirellis etc often pulling a Jayco Discovery Outback
                [/b][/color]
                  Sunshine, Contact Matt direct by either PMing him DigiOptions or email him [email protected].
                  [COLOR=#000080]Nick[/COLOR]
                    I have just put one in and it was EASY. I am in north brisbane if you wanted a hand.
                      Great; thanks for the contact
                      [color=#fa0c23][b]
                      Brian
                      [/b][/color]
                      [/b][/color]
                        As bdearth has said, the install is pretty straight forward, I would almost say that the camera and wiring took me longer than the head unit which almost falls into place. I am also on Brisbane Northside.
                        06GXL V6, Sovereign Bull Bar, OEM towbar, OEM (Rhino) Aero Bars, Rhino AT1510 roof basket, DIY roll out awning, DIY Dual Battery, Electronic rust protection.
                          Hi Matt,
                          I have installed the firmware update from the link you emailed me. I guess we will have to wait and see how things go but the GPS appears to be working fine at present.
                          How do I go about updaing the IGO8 maps that come pre loaded. The maps do seem to be dated and would like to install the latest available. Is this something that can be purchased through yourself or does any one else have info on this topic?
                            Hi Matt,
                            Hi there, please email me at [email protected] and we can discuss your options. Cheers, Matt
                              I have just finished the install of the new AVN11TP (Upgrade TP09X1) What a great unit, Seamless fit to the dash of the 150GX and easy to install. The rear camera was a challenge but well worth the effort.
                              I recomend this one to anybody looking to upgrade.
                              Peter
                              P.S. I had written a long winded glowing report of the unit and install but when I went to submit, the system asked me to log in again and I lost it all. Poo to that!
                              Edit: Delete "Premium" Insert "Upgrade"......Still love it no matter what you call it.
                              GX 150 White. D4D. Factory Alloy bullbar, Factory Towbar, Sidesteps, 7 Seat Opt, Bug Screen, Seatcovers, Window Tint,
                              Dig Opts Fangle-d Wireless.
                                Had my unit installed today and everything seems to work. The software for the GPS unit is dated 29 November 2009 so I'm presuming that there is an update since then so I have sent off an email to Matt. The reversing camera is good too and we adjusted it so that I can see the towball for connecting the camper trailer but still get a good view outback as well. My phone works with Bluetooth with the unit too but there already was a Bluetooth unit under the dash that was installed by the last owner, I guess.
                                So if anyone needs a good installer in Brisbane; I have the number of a good auto-electrician who was suggested by Matt.
                                [color=#fa0c23][b]
                                Brian
                                [/b][/color]
                                [/b][/color]
