Re: Dig_Options TP09X1 GPS, Reviews & Information
I've got mine adjusted so that I can 'just' see the tow ball/trailer hitch when its in. I didn't want to have it pointing too low and miss out on the advantage of reasonable good rear view distance.
While the camera bracket can be bent and twisted a bit to help get it adjusted as required, I'd recommend doing a bit of a test fit using double sided tape or just one bolt first to ensure you can get it the way you want it. Note that depending on the tyre size/type of your spare, you may not be able see the actual bumper.
