12" Tablet Laptop for Topo Navigation
  • 12" Tablet Laptop for Topo Navigation
    Here is my solution to Off Road Navigation \
    If you need the very best in off road navigation then look no further.
    This set up be it $3500 does off road navigation very well, as well as all other features your home pc can do.
    I use this set up for when I am working and need to not only no where I am but also map and log into the unit which is often fiddly to use when using lighter programs running on Windows CE not to mention only 4-7" screens.
    I use a 12.1" Motion Computing Tablet that I bought from the states, custom mounted near the dash of the Prado. (Approx range between $1500-5000 Australian) As you are only running the mapping software not editing a blockbuster, remember you only need middle of the road. Most people are using old Pentium III Laptops with only 128MB of Ram.
    My picks of the Range would be a Motion Computing LE1700 or LE1600 with a 60GB Hard Drive. (This is what the Variety Officials Use, run fantastic, and cost about AU $1500.)
    An iGPS-M Mouse is used to input the GPS Data but any USB NMEA input would be fine. (Approx $50 Australian)
    The most expensive part of my setup was the Maps. However, these have been gradually acquired and to start with, you would only require a copy of either
    (Ozi Explorer with Natmap 2008) approx $60 + $200) or Memory Map Tour $200 (In my opinion the best value)
    Software is open-ended as the Tablet runs Windows XP/Vista.
    I personally run the following
    Memory Map Topo which Covers Victoria, New South Wales, Queensland, Tasmania, New Zealand in 1:25000 or 1:50000
    Memory Map Tour is used to cover all states in 1:250000 as well as all Hema's Digital Maps
    Memory Map Rooftop is used to cover Victoria and New South Wales as an alternative to the other maps (Very Useful Off Road)
    Ozi Explorer is used as well due to many other people using it, (Mainly Variety Bash SA Officials)
    Maps here are as Follows
    NATMAP Raster Premium 2003 1:250000
    NATMAP Raster Premium 2005 1:250000
    NATMAP Raster Premium 2008 1:250000
    Flinders Rangers is covered from Nth to South by 1:50000
    Eyre Penisular is also covered from Est to Wst by 1:50000
    Also have a copy of Rooftop, and Hema Great Desert Tracks Installed
    Just added Co-pilot Live for Turn-by-Turn Navigation, it works well and finds lots of shortcuts between NE Victoria and Adelaide, Lot better than the TomTom
    If you want to run both applications at one time then you will need a virtual com port application
    I use XPort or Franson GPS Gate 2.5 (Both free downloads)
    As for the Install Here are some pic's of the custom Stainless Steel Mount
    This is the Top of the Mount, Inside the sleve is a nylon bush to ensure no rattles and the wing nut keeps it possitoned.
    The mount attaches under the passangers seat bolts and has a piece of flat running to the rear right seat bolt
    The screen is held to the bracket by Stick on Velcro, I have 2x 300mm x 20mm strip about halfway down and every time i go to take it out i nearly pull the plastic cover off the screen it holds that well!!!!!!!!!!!
    It sits only just above the dash but I may lower it down to be level with the dash. It was originaly positioned this height so passanger could still get to climate control switches.
    The GPS Mouse sit on top of the Dash and is held in place with some Velcro or a cable tie and is positioned where there is no airflow for demisters.
    2011 Toyota Prado 150, GXL D4D Auto, White
    Mickey Thompson ATZ, Hayman Rees TowBar,TJM T3 Customised with 4x Hella Predator's, Phillips HID Low Beam, Shuroo, Roof Racks, Dual 100ah N70zz Batteries, IC 400 PRO, GME TX 3600, ZTE T165i Car Kit, Projecta 600w Inverter, Motion Le1700 Tablet, Engle 45L Fridge.
    Re: 12" Tablet Laptop for Topo Navigation
    Looks like a handy bit of kit. How do you go with clearance from the airbag on the left hand side of the tablet? Couldn't really tell from the piccy's.
    I am running an Eee Pc 900 which at this stage doesn't have a mount, but fits snuggly into the top space of the glove compartment.
    Black 2008 D4D GX, Bolle tint, Airtec snorkel, Hayman Reese tow bar, Staun deflators, ARB Air, front & rear extended diff breathers, Milford cargo barrier, Poly Air, 2" lift, XGS suspension, road tyres - 265/65x17 Grandtreks, play tyres - 265/70x17 Wrangler MTR's, ARB Sahara Bar, TMax 9000 winch, custom winch panel, Uniden UHF, Garmin 76csx with RAM mount, Eee PC with OZI, triple IPF 900XS spotties, rear ARB diff locker, Brown Davis underbody protection, Darren McRAE Auto Craft Rock Sliders
      This was taken into consideration, the pole would when tablet is not on the mount and generaly covers from left airvent towards the right
      half way accross the stereo headunit.
      I also take it off most of the time due to theft issues when on the black top
        Just a quick note, This unit (Motion Computing LE1700) is now For Sale, please contact me to discuss exact details, but what you see is what you get apart from Memory Map Software and the Mount can be discused as well. I am in the process of rebuilding for a new J3400 Tablet work has purchased for Me.
        Refer to For Sale section for full details.
        You can email me [email protected]
          Just upgraded this to suit a 150 dash see my build up for pics.
              WOW.. very nice indeed....
                Nice, got a link?
                  Originally posted by Peterpilot View Post
                  Nice, got a link?
                  if you go to their profile and click on all threads you'll find it...
                  http://www.pradopoint.com/showthread...-s-150-GXL-D4D
                  great mount by the way.
                  2011 150series GXL
                    Great bit of kit you've made up there. Just be mindful that if you have a crash and things go bad, you may run into trouble if your modification isn't ADR compliant. I know with our in car computers at work we're supposed to have a foam rubber sheath over the computer when it's not in use and store the sheath in the car when it is in use. Just putting it out there.
                    Mike
