My Rig
    Originally posted by brentonsav View Post
    really nice example coming along here. very interested to hear what you think of the the outback drawers as I'm tossing up between these of the black widow drawers. the local 4x4 shop who sells both recommended the arb item over the black widow option, as they're about $400 cheaper and as good, if not better quality and fit.
    Gidday mate, I have outback drawers......this is my second lot, the first being on a 100 series. The handles on the ARB one are better than the black widow drawers......much more user friendly.....Hope that helps.
      Matt-mr4x4, will dig up the part #'s for the coils and post tomorrow..
      Derek11, I am keen to find out first hand myself on the tank, the honest answer i got from the tank maker was that they cannot 100% guarantee complete accuracy of the tank working with the OEM trip computer/ fuel guage but in trials so far their have been favorable responses. A lot comes down to the people fitting the tank, we have fitted a lot of long range tanks to a lot of different fleet vehickles at my workplace, it's a bit of trial and error getting the guage on the tank to sit in the sweet spot that works acurately but haven't had any problems on any vehicles yet. This is the first 150 Prado though so will see how it goes.
      Outback7, haven't had any dramas with the Kaymar bar so far. As long as the people fitting do a good job you should be right, couple of things to watch if you go the dual wheel. make sure there is a good gap between the left wheel carrier upright arm and the replacement door handle panel they fit. It can be a tight fit but you need good clearance or the upright arm will bang on it. Make sure they fit so the sidewings run flush with the panels, there is a support arm for the wings that can get pushed in when being transported that will make the wings sit inside the guard if they dont line them up properly and that will look shithouse.
      brentonsav, i picked the outback drawers over the ARB because of the height. ARB overall height is 320mm where the outback is 280mm. I have a mate that has the ARB ones and they just look that little bit too high for me. I liked the blackwidow ones too because they were only 275mm but i prefered the drawers on the outback for the finger gap at the top of the drawer to eliminate the possibility of being in the bush and someone jamming their hands in them. could be a very painfull injury with the weight of a fully loaded drawer.
        OUtback7 I too have a Kaymar fitted and have done for the best part of a year. Not sure what ARB are talking about with plastic bit but I can say that I've stood on mine to load the roof rack as well as packing the rear and never had an issue. I have the wheel carrier on the right and a twin jerry can holder on the left so don't have the issues Daimar96 spoke of re door opener. Might add, after coming back from Lakefiled late last year the door was a little hard to open. i think it was due to the excessive amount of bull dust in the mechanism. After a decent clean and some dry lube, it's fine. I would highly recommend the Kaymar.
        Dusty
          Spectacular rig, I wish I had a build spec like that! Congratulations.
            Thanks mate.
              Dusty
              Thanks Dusty.....where I meant was on the side guard that the steel bar butts up too. That is flimsy. Have you found that?
                Kaymar provides a bracket that is riveted to the inner guard which prevents the quarter panel from flexing. The plastic guard isn't attached to this, it just rests against it. Mine was the first to be fitted by ARB here in Cairns and there are some niggly little things, but all in all I wouldn't be without one, despite the high cost.
                P.S. Sorry for hijacking this thread,
                  Thanks Dusty......well, it looks like a rear wheel carrier for my 150. Expensive though mate.......how am I going to tell the wife?........lol.
                    Matt-mr4x4, part #'s for the TJM suspension
                    659GE188L - Front Strut (each)
                    650GE288L - Rear shock (each)
                    770FRHD881 - Front Coil (Pair)
                    770RRHD881 - Rear Coil (Pair)
                    65212995TO - Poly Air Kit
                      thanks mate. Any chance of posting ya lift heights ? From the bottom edge of the wheel, thru the center up to the wheel arch ?
                      matt150
                      [CENTER][B][U]Matt
                      [/CENTER]
                      [SIZE=2]
                      [/SIZE][CENTER][SIZE=2]
                      [/SIZE][/CENTER]
                        Front is 925mm and rear is 995mm from the ground to the lowest point of the guards through the centre.
                          Hi All, I picked up my 2012 GXL TD Auto at the end of November last year and love it. We live in Mount Isa and had a trip up to Cairns, Port Douglas, Cape Tribulation for Christmas.
                          ARB - Deluxe Bull Bar
                          ARB - Side Rails
                          ARB - UVP
                          ARB - Dual Battery
                          ARB - CKMA12 Air Compressor
                          ARB - Extreme Hi Lift Jack
                          ARB - 47 ltr Fridge Freezer
                          ARB - Fridge Cover & Tie Down Kit
                          ARB - Premium Recovery Kit
                          Warn - XD9000 Winch - (Just arrived - Fitting This week)
                          Brown Davis Long Range Tank - 135 ltr - Waiting for it to arrive..
                          Outback Drawers - (Just arrived - Fitting this week)
                          Safari Snorkel
                          Rhino Pioneer Roof Rack - (Just arrived - Fitting this week)
                          Foxwing Awning - (Just arrived - Fitting this week)
                          Max Trax
                          MSA DS40 Drop Slide
                          Hella High Boost IX XGD Pencil Beam
                          Hella High Boost IX XGD Spread Beam
                          Clear Covers
                          GME TX3820 UHF / Remote Hand Piece
                          Smooth Talker Hands Free Iphone Cradle / Charger
                          Kaymar Rear Step Dual Wheel Carrier
                          Mickey Thompson BAJA ATZ 265/70R17
                          TJM XGS Gold Edition 2" Lift Kit & Poly Air Kit
                          Extra Alloy Wheel
                          Lock Nut Set
                          Bonnet Protector
                          Headlight Protectors
                          Weather Shields
                          Dash Mat
                          Floor Mat Set
                          Cargo Mat
                          Black Duck Seat Covers
                          TG150 Transfer Case & Actuator Guard
                          Cheese & Rice!! That ARB salesman just got the xmas bonus of all time
                          Seriously jealous Daimar96..
                          2008 Charcoal 120 GXL - D4D Auto with Option Pack
                          [URL="http://www.pradopoint.com/showthread.php?33254-MYBO-s-Charcoal-120-GXL"]My Build Up Thread[/URL]
