Joey's rig build up
  • Re: Joey's rig build up
    Well tonight i fitted up my boost controller....oh what fun in 100 per cent humidity....
    firstly big thanks to Mick L for the thread and the expertise in these areas...made my job easy...
    well started by pulling the engine to pieces
    next was a real pain as if you didnt have tiny fingers( i dont ), you were in for a hell of a time...
    time to connect new hose to the wastgate pie and off the turbo....it took ages but got it done !!!
    time to put it all back together...
    meat meets metal.....metal wins....told you it was tight in there!!!!
    bought one of these from the states a while back and has improved vacum and i think it has been working a treat for the past 6 months...
    this is the boost controller...top quality and excellent warranty and service ..made in melbourne ..turbo tech its called..
    this is all the bits back on...
    and now with boost controller...not a permanent spot just trial for now...
    will do all the tests 2morrow..
    cheers
    -issue 52 Modified 4wds .
      Lookin good mate, the old girl should go well now with all the go fast bits.
      Crammy
      2008 GXL M6 D4D, Silver
        how crusty does the engine bay look though after our mission the other day!!! 8)
        joey
          I was about to say joey, you been driving through Iraq or something?
            gave it a bit of a wipe down this morning.....
            only slightly crusty now....
            joey
              Nice rig Joey, lookin great bud.
                well today i took the rig down to Lee Holmans special vehichle service for a run on the dyno..and a tweak or 2..
                i was amazed at the difference from standard....
                kw at the wheels...88kw...(thats with the stt's).....
                torque ...520 N.M
                motive force.....4977.5 N
                running at 14.7 p.s.i
                my rig standard is only 97kw at the fly wheel.....and torque is 370 .n.m
                so as the stats say a massive increase in power.....
                and it feels better 2..
                we adjusted the chip and the fuel to air mix is better...
                well i am happy as...
                joey
                  Hey Joey,
                  Any more mods on the cards before you have the photo shoot with 4WD Action?
                    Originally posted by joey
                    well here are some pics of the latest mods...
                    and i put this turbo timer in a while back....
                    Hi Joey
                    Where did you get the turbo timer from, is it plug and play?
                    Cheers, Andy
                    Black 2003, TD, GXL Prado
                      Hi Joey.
                      Cheers, Andy
                      yes mate its plug and play...bought it off ebay...works a treat..$150
                      joey
                        Thanks Joey
                          Thought i would follow suit and do a build up of my rig...
                          2005 turbo diesel gxl....
                          exhaust gas temp gauge
                          boost /psi gauge.
                          .diesel performance chip
                          .toyota bonet protector
                          .toyota dust shield
                          .weathershields
                          .opposite lock recovery gear
                          .safari snorkle
                          .i.p.f extreme 900 spotties x3
                          .i.p.f extreme blue spottie covers
                          .cooper stt tyres
                          .bilstien shocks
                          . king springs 50mm lift
                          .poly air bags
                          .D.Y.I front bash plate
                          .U.H.F plus 2x handhelds
                          .Tom Tom g.p.s
                          reverse camera
                          .platinum sheep skin seat covers
                          .canvass off road seat covers
                          . imitation sand grabber mats
                          .fire extinquisher and fire blanket
                          .comprehensive first aid kit
                          .prado point sticker
                          .gnarly characteristic scratches..
                          nylon wheel spacers
                          T-Max 9000lb winch -in cab controller
                          blue tounge air compressor under bonet
                          kaymar rear camp/work light extendable....
                          milford cargo barrier.
                          dual battery system.2x 12 volt rear plug, 1x engel fridge plug.
                          80 L engel, 8L engel...
                          custom deluxe arb roof rack
                          lightforce 140's x6 roof mounted.
                          ARB DELUXe winch bar
                          beaudessert 3 inch exhuast straight through with 3 inch dump pipe.
                          fridge slide
                          extended under bonet diff breathers
                          boost gauge
                          in cab battery monitor
                          browns davis bash plate.
                          on the list to come
                          ..lockers front and rear.
                          .rear drawers
                          .roof rack
                          :arrow: This is how she arrived home....
                          :arrow: then came spotties and snorkle...
                          :arrow: UHF and seat covers....
                          :arrow: bilstein king spring and poly airs...and cooper stt
                          before the lift.....
                          and after....
                          :arrow: reverse camera and G.P.S
                          :arrow: D.Y.I front bash plate...
                          :arrow: third I.P.F spottie and new covers
                          last but certainly not least Prado Point sticker
                          here a couple of random shots.....
                          here is the latest and easy mod... wheel spacers..
                          high tensile bolts10mmx50mmx1.25mm thread pitch.
                          the spacers are nylon that has been turned on the lathe.
                          thanks crammy for the help on this one mate :
                          here is some new stuff..
                          9000lb T-MAX winch.
                          fitted in the cab
                          new BLUE TOUNGE compressor
                          Kaymar rear light
                          extended diff breathers
                          got some new recoveery gear while i was at it..
                          ok added milford cargo barrier and a couple of life hammers today.
                          dual batteries....
                          new diff breathers..
                          80 litre engel and extras..
                          rear camp table...
                          8) 8) 8)
                          thats all so far but more will follow...
                          my rig might have a few scratches but it has been tested and measured , and proven itself many times .. i know she will take me where ever i want to go...dont be frightened to give them a bit of stick.. you will be pleasently surprised!!!!
                          oh how did that get on this page!!!
                          01/04/08 18kg of machine
                          Very nice looking prado,How do i get a pradopoint sticker??
                            Hi ya pradojon,
                            There is a thread for the stickers... http://www.pradopoint.com/viewtopic....ker+pradopoint
                            Oh, and please be considerate of dial-up users and only quote images when it's relevant...
                            Cheers, Leon
                            Optix Photographix
                              Nice Rig Very nice Good job Joey
                              Trev L
                              Prado 2003 with a OME 2 inch lift, ARB Delux Bullbar, Warn magnum winch, IPF 9000 spots, Safari snorkel, Daul Batterys, UHF Radio with remote head unit, extra Power outlet, 265 70 17 MTZ's, ARB CKMA12 Compressor, TrackLander Roof rack with two Rear Work lights, rear anderson socket, twin DVD Players, Indash DVD,GPS, running IGO 8 and OziplorerCE, Custom Drawer System
                                Awesome rig mate...
                                If i did half of that (and I want to) to the blank black canvas that I call my own... um, cough.. the handbrake's! I'd be in so much trouble... ops:
                                I might have to wait until this one is paid for and I buy here the newer model, before i can really go to town on the mods!!!
                                Your's and Crammy's are the inspiration for the future end result
                                You've done well, very impressed!
