Jcas24 prado on the RTI Travel ramp.
    Re: The Prado Project. Jcas24
    Originally posted by pradogxlv6
    Looks like rock sliders are next Joel...
    Yeah i reckon, I was talking to my welder mate about it the other day. Heres the shot I need the sliders :P
    2000 Toyota Prado GXL- Gone, but not forgotten...
    '92 Landcruiser HDJ80 4"lift 33's
    '91 Surf LN130 coil sas, 4.8s, 35s
    '12 Jayco Eagle Outback
      KK time for an update. I have may a false floor with some boxes underneath. covered it in carpet and its looking schmicko. Bought a fridge slide of a mate in the 4wdclub and in the process of cleaning it up and repainting it.
      just gotta hook up the 12v pump and stuff
      I also have all the tube for the sliders so I will have to pull my finger out :mrgreen:
        Holy cow! is that a 15" subbie in the back hahaa, nice work man
          Awesome buildup Joel, she looks mean with the big tyres and 4" lift. Nice work on the shelf in the back, you have given me some good ideas for my rig.
          Was there much involved in doing the body lift ? Was it costly ?
          How have you found the ARB compressor ? Does it handle pumping up 4 tyres without over heating ?
          Alan
          99 GXL V6, 2" EFS suspension lift, ARB winch bar, Mickey Thompson ATZ 4ribs, ARB on board compressor,front and rear airlockers, Hella 4000's, ARB ally roof rack, Ausguard cargo barrier, Safari snorkel, t max 9000lb winch, t max recovery kit,105 amp/hr Thumper dual battery system, Waeco CF50 dual zone,OZtent RV5, ERPS rust protection, PP stickers.
            Forget rock sliders. Looks like you almost need a full exo-cage if that's the kind of terrain you're driving in!
            Looks good.
            [color=#BF4000]2003 V6, Auto, GXL, Factory Bullbar, Rhino Roofbars, Bosch and Hella spotties, Cooper AT3, Bilstein shocks, Ironman awning, GME UHF, MaxTrax.[/color]
            [url]www.kymarphotography.com.au[/url]
              Originally posted by jcas24
              Originally posted by VL400
              Looks the goods!
              Are you able to post up some pics of the rear worklight? Am wanting to add one but there is not much room behind the spare so would be intersted in the mounting. Thanks
              Ok, heres the rear worklight pics,
              That idea of how the light is mounted is mint!!!
              2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
                that is awesome! dumb question where do I run that cable through to the inside, is there a place without drilling a hole haha.
                Need to make up one my self, dads a welder, and he loves small jobs like this. As the artist in I I am useless at all things welding since high school lmao!
                  Hey guys, thanks for the comments.
                  Alan, The body lift was alot easier then expected. $120 for the bodyblocks with have a steel crushtube and are black so they don't stand out like dogs balls. I got the bolts, washers & nuts from work. I did it myself in a day of mucking around, only had to lower the radiator, which has mount holes 2inches lower then standard and customise the bullbar mounts to suit.
                  The arb compressor pumps up a mates 37inch tyres from about 6-8 psi to road pressure in about 4mins a tyre, hasnt overheated yet.(not 100% what his road pressure is, cause I let him pump em up.)
                    Top stuff Joel...
                    Gonna measure up my truck this week.. another project for N/Shift, next week
                    Good work Matt. they are very handy, my driveway is 20m long and dark and Ang likes having the light for reversing. Only thing is its not hooked up to reverse gear, its on a seperate switch. I've only accidentally left it on once.
                    Justin, this light bracket came on the car when we bought it, but it is a very clever design & simple too(although it wasn't wired up?!). I did drill a hole behind the wheel bracket. I just made sure the hole was touched up with paint and i put a gromet in the hole then ran the cable though that.
                    Next mod apart from sliders is a double-din reverse camera/dvd/satnav/everything, that I have mentioned early in the thread. I backed into another tree the other weekend ops: :cry: it hit on the spare and pushed the rear door skin in a bit, so it hasn't taken much convincing to gain aprroval. :wink:
                    cheers,
                    Joel
                      Its a 12inch Kicker VR Comp sub, and it kicks :lol: even though Im not into that doof doof music, it still adds to low tones that you otherwise dont hear with cardboard cones standard door speakers. lol
                      Its the first thing to go once we need to put a pram in there, but shouldn't be long after that and I'll have another 4b to put it in.
                        Thanks for the info Joel, i'm getting an ARB compressor fitted next week as well as front and rear lockers 8) and I'd hate it to cut out after 2 tyres like the inlaws TJM big red always does.
                        I think i might have to look into a body lift down the track so i can fit some bigger tyres. Did you still have to trim bits of the car to stop tyres rubbing, or did the body lift sort that problem ?
                        Alan
                          Alan, I do still get minimal scrubbing on the drivers side but only when the suspension is compressed and near full lock. I have removed the front mudflaps and cut away some of the inner guard that sticks out. I could cut more away and I still haev to have the castor adjusted. this will happen when I change back to the landcruiser wheels with a more suited offset. the rear rubs slightly on the inside upper guard at full compression.
                          I still want a front locker, but I won't spend much more on it as Im planning on building something for the harder tracks im starting to do. Dont wanna trash the prado and we'll keep it as our tourer/holiday car.
                          you will be suprised at the places you will go with the lockers. i want, iwant /jealous :wink:
                          Also everyone that has used/seen my compressor have being most impressed including Matt
                          • #28
                            Thanks Joel. Can't wait to get the lockers fitted then i'll get out there and do my best to get stuck :lol: .
                            By the looks of some of your action shots in this thread and the other thread you just about need a locker or 2 with those front wheels up in the air like that, cool shots by the way. Once again nice rig mate.
                            Alan
                            • #29
                              Re: Jcas24 prado on the RTI Travel ramp.
                              Put my Prado up on the Travel ramp today at the local TJM Open Day.
                              I was impressed with an RTI score of 450. Another Prado in our club scored 436 and a GU patrol that went before me only scored 392. So I was pretty happy with that.
                              For those that dont know, RTI = Ramp Travel Index, its a way to measure the flex/articulation of a 4wd. To get an RTI score :- distance travelled up ramp divided by the vehicle wheelbase x1000 = RTI score.
                              • #30
                                not prado related, but meh, enjoy
