I'm not sure if Giles still hangs around on here. But if you do Giles, I was wondering how hard it is to get to the fridge slide catch to put the slide back in once youve pulled it out?
If you see the car in the flesh it has some bush pin striping. Also it was recently in one of the 4wd mags for a photo shoot at Stockton Beach.
Nothing like seeing all that good gear being put to work, I don't get access to magazines where I am so rely on what I see on the forum, I really like the rear bar on the 150 would be good if there was something similar in make for the 120.
[FONT="Comic Sans MS"][SIZE="2"]09 D4D Prado - Toyota issue White
Wrench, Wheel, Wreck, Repeat... [/SIZE][/FONT]
1) The Steinbauer can be tweaked to suit the exhaust which is not a problem.
Not really much more info i can provide at the moment on the exhaust,i don't have the exact spec sheets yet but why what we can feel it's
made a big difference.
2) The ARB compressor is Bolted to the Floor
The Air Line goes through the floor via a gromet
The harness runs to the kick panel,along the trim where the door is,up and through the dash into the engine bay!
Hope this helps.
Giles
Giles,
Can this be put on at home without the hassel of re-tuning the Steinbauer on a dyno ? Or does it have to be done at the same time as the exhaust system fit up ?
[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
hi giles i have just purchased a 2011 kakadu and was wondering does the radar and front camera still work ok with the bar fitted i had a arb bar on my 120 and want to do the same on my kaka
Can you tell me what the Kakadu wing brace kit is for the Kaymar rear bar in the quote I just got from ARB?
Crystal Pearl Altitude 150 Landcruiser Prado. TJM sensor bar, brush guard, side steps. KM2 BFG on GXL alloys. Kaymar bar, Drifta and MSA fridge slide. ARB locker and compressor, and MK11 compressor and fuel filter bracket.
