"Spot the Spot"
  • Not Undara is it
    • No Not Undara, but your getting closer. We went to Undara 2 weeks after we were here, all the tours were fully booked though so we didn't see much there!
      • Here is the entrance to the, as NTP put it, one helluva pothole.
        • Another pic from a the same area
          • Cania Gorge?
            Politicians And Nappies Should Be Changed Often - And For The Same Reason.
            • I have no idea where it is, but it looks spectacular
              • Canarvon Gorge? I think from memory that is the Amphitheartre and possibly the Moss garden?
                  Correct on all counts! Have a go.
                  • BOk, try this one folks. It even has the Prado in the background with the mainsail up! (SEQLD Crew will know what I mean...)
                    craigm
                    Addicted PP Member
                    • Old Cork Station?
                      Ron
                      4WDriver since 1975, current 4WD, 2009 GX diesel auto 150 series, fitted with ARB bullbar, snokel, dual batteries, rear draws, water tank, mud tyres, side steps, 50mm lift & roof bars. Tow a Olympic Champion XPack caravan, travelled a lot of Australia, past big trips in 150, August 2010 - Hay River Track NT, July 2011 - Kimberleys and WA, July 2013 - Canning Stock Route WA.
                      • Thought it would be a bit too easy... Well done!!
                        • Try this one, I tried to be smart, lighthouse on top of Prado.
                          See how you go, will post another photo if this proves too hard.
                          Ron
                          electron
                          • Point Quobba north of Carnarvon
                            Violet
                            (If it swims - chuck a fly at it)
                            • Well done. I thought I would have to give more clues.
                              Ron
                              • Sorry I'm late - computer problems. I'm running out of shots....
                                Violet
