WTB: 120 Grande Sportz Bars
  • WTB: 120 Grande Sportz Bars
    G'day everyone. I'm looking for s/hand Rhino sportz bars (SXB3) to suit the Prado Factory Roof Rails. Minimum length 1250mm is what I think they are? Brisbane area preferred.
    Hi Craig
    The bars are also the same as the Kluger bars so keep an yey out for them as well.
    Regards, Richo.
      They also fit the RAV4 rails.
        Thanks guys. I have an old set of SXB racks from our old SanteFe (2001) that are'nt wide enough and the rail mount profile has since changed. I was aware that the SXB brackets are the sames as they are for "most" factory rails systems, buI need to be sure that the crossbar length is same as Prado. I rang Roofracks Galore and was told 1250mm. they want $80 p/rail to suit my old sxb mounts. I dont think the RAV's would be this wide, probably 1120mm? If I can't find a bargain out there, then I will probably have to bite the bullet and buy 2 new rails.
        craigm
        Addicted PP Member
          PS Craig
          If you do go to buy new bars shop around as I found Roof Racks Galore to be more expensive than 4WD shops that I have purchased other products at as they gave me a discount probably based on my spend to date. (ARB Coopers Plains).
          Regards, Richo.
            Cheers Richoson. I'll keep an eye out on ebay and here for a couple of weeks before I need to shop around at the stores.
              I have a set of rhino rack bars on my grande at the moment cant remember witch ones. will have a look and get back to you tonight
              Case
              Former Grande Owner
              2003 V6 Grande, Pearl white, TJM bulbar, ARB under bonnet air compressor, HID Lightforce genesis spotlights, 50MM Suspension lift (yes a proper airbag lift)
                Thanks Case. Can you let me know length of bars please?
                  Hey Craig, i think you misunderstood me (Probably cause i ddin't say what i meant)
                  i have Rino rack sport bars x2 that came with my new prado
                  i have a rooftop tent that i bought for my previous land cruiser and rino rack HD bars(i think there called) so i have bought new legs for those bars to fit the prado rails
                  i have only had my prado for 3 days and these rhino rack sports bars came on it, i don't want them
                  if you find out how much to get them to you from me (mackay 4740) you can make me an offer on them
                  Case
                  Former Grande Owner
ID:	636080Click image for larger version
                    they cant go in a pm
                    Former Grande Owner
                      Thanks Case. Not quite long (or wide) enough for my requirements. Will keep looking... (just too fussy!!!)
                        Just check that the 1250mm bars will fit the 120 Prado as there are only minimal movements in the feet for the width on the bars. The HD bars I have are 1250mm wide but I think the Sports bars are 1120mm from memory as I put them on my mothers Rav4 (so I can carry stuff on them).
                        Paul
                          Thanks Paul. Although I haven't seen the 1250mm sportz bars up real close, it should just be a matter of peeling out more of the slotted channel for the bracket to slide in to my required width. I am told this isn't to hard to do so it shouldn't be a problem..
                            Hi, we have Rhino Sportz Bars (set of three) that will replace your roof rails if you are interested.
                            Regards
                            Matt
                            Matt - Silver 2009 Kakadu. BF Goodrich, Aero Racks, nudge bar, electric brakes, Incubus wheels and mud mats through-out.
                              Have now sourced a set of SXB3 Sportz Bars (Ebay) Thanks for the offers etc....
                              Mods this can now be closed.
                              Craig
