G'day everyone. I'm looking for s/hand Rhino sportz bars (SXB3) to suit the Prado Factory Roof Rails. Minimum length 1250mm is what I think they are? Brisbane area preferred.
Thanks guys. I have an old set of SXB racks from our old SanteFe (2001) that are'nt wide enough and the rail mount profile has since changed. I was aware that the SXB brackets are the sames as they are for "most" factory rails systems, buI need to be sure that the crossbar length is same as Prado. I rang Roofracks Galore and was told 1250mm. they want $80 p/rail to suit my old sxb mounts. I dont think the RAV's would be this wide, probably 1120mm? If I can't find a bargain out there, then I will probably have to bite the bullet and buy 2 new rails.
If you do go to buy new bars shop around as I found Roof Racks Galore to be more expensive than 4WD shops that I have purchased other products at as they gave me a discount probably based on my spend to date. (ARB Coopers Plains).
Regards, Richo.
I have a set of rhino rack bars on my grande at the moment cant remember witch ones. will have a look and get back to you tonight
Case
Former Grande Owner
2003 V6 Grande, Pearl white, TJM bulbar, ARB under bonnet air compressor, HID Lightforce genesis spotlights, 50MM Suspension lift (yes a proper airbag lift)
Hey Craig, i think you misunderstood me (Probably cause i ddin't say what i meant)
i have Rino rack sport bars x2 that came with my new prado
i have a rooftop tent that i bought for my previous land cruiser and rino rack HD bars(i think there called) so i have bought new legs for those bars to fit the prado rails
i have only had my prado for 3 days and these rhino rack sports bars came on it, i don't want them
if you find out how much to get them to you from me (mackay 4740) you can make me an offer on them
Case
Former Grande Owner
Former Grande Owner
Just check that the 1250mm bars will fit the 120 Prado as there are only minimal movements in the feet for the width on the bars. The HD bars I have are 1250mm wide but I think the Sports bars are 1120mm from memory as I put them on my mothers Rav4 (so I can carry stuff on them).
Thanks Paul. Although I haven't seen the 1250mm sportz bars up real close, it should just be a matter of peeling out more of the slotted channel for the bracket to slide in to my required width. I am told this isn't to hard to do so it shouldn't be a problem..
